Changing the Home location on an Acura NSX Navigation System
The Go Home button on your Acura NSX navigation system can be programmed to allow you to quickly navigate to your home location. At times, you may need to change this location or reprogram it. This can easily be done from the navigation system.
To Change the Home Location:
1. Touch Navigation
2. Touch Where To?
3. Touch Saved
4. Touch the saved location labeled "Home"
5. Touch the the info button (letter i in a circle)
6. Touch the menu bars (3 lines)
7. Touch Delete
8. Touch Yes
The home location will now be deleted. You can return to the main menu and touch Go Home to set a new location.
