Maps Missing from Map Information list
Updates to the device's software have altered the way the devices list mapping. Previously, devices only supported a single mapping file, which could contain all of your various mapping products depending on what was chosen before map transfer.
Now you are able to load multiple mapping files to your device, and enable or disable each of these files as needed.
No mapping products are missing from the Map Information screen. Instead all mapping products are listed by each supplemental map file. MapSource® software can fail to properly install the mapping files as it is legacy software.
If you are using the MapSource program, install MapInstall™ software to properly load mapping to your device.
You will now be able to manage each of your supplemental map files under Map Information. If more space is needed, delete the unused map files from the device or microSD card.
