Mounting the VIRB 360 Upside Down to Record Video
The VIRB® 360 can record video while mounted upside down. The VIRB® Edit Program can correct the video's orientation.
  • Video can be stabilized regardless of camera orientation.
  • Inertial and Orientation data will be relative to the camera's normal orientation.
  • Gauges showing G-Force or Compass Heading will appear inconsistent with stabilized video if the video orientation is upside down.
  • VIRB Edit's Stabilize Only or Follow Path can be used to automatically correct the video orientation.
  • Video can be manually flipped using the Rotate 180° option in the Editing tab.
