ICAO PBN/RNAV-RNP Codes
The tables below describe entries that are made in Field 18 (Other Information) on the ICAO format FAA Flight Plan (FAA Form 7233-4).
NOTE: Reference your navigator and transponder's Aircraft Flight Manual Supplement (AFMS) for details on which codes apply to your avionics.
For integrated flight decks, consult your OEM.
ICAO PBN/RNAV-RNP (part of Field 18) Operators should file their maximum capabilities in order to qualify for the most advanced procedures. Select a maximum of eight entries to follow PBN/ | ||
Capability | PBN/Code | Notes |
OCEANIC/REMOTE CONTINENTAL PHASE | ||
RNAV 10 (RNP 10) | A1 | Area Navigation (RNAV). RNAV 10 supports lateral and longitudinal separation minima in oceanic and remote continental airspace. RNAV 10 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 10 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNP 4 | L1 | Required Navigation Performance (RNP). RNP 4 is associated with operations in oceanic and remote continental airspace. RNP 4 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 4 nautical miles. This accuracy must be achieved by at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. RNP adds to RNAV accuracy standards by requiring onboard navigation performance monitoring and alerting. |
ENROUTE PHASE | ||
RNAV 5 All Sensors | B1 | Area Navigation (RNAV) using all available sensors. RNAV 5 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 5 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNAV 5 GNSS (GPS) | B2 | Area Navigation using the Global Navigation Satellite System (GNSS). RNAV 5 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 5 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNAV 5 DME/DME | B3 | Area Navigation (RNAV) using Distance Measuring Equipment (DME). Able to calculate position w/in 5 NM radius at least 95% of the time. RNAV 5 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 5 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNAV 5 VOR/DME | B4 | Area Navigation (RNAV) using VHF Omni-directional Range (VOR) and Distance Measuring Equipment (DME). RNAV 5 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 5 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNAV 5 INS or IRS | B5 | Area Navigation (RNAV) using Internal Navigation System (INS) or Inertial Reference System (IRS). RNAV 5 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 5 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNAV 5 LORANC | B6 | Area Navigation (RNAV) using LOng RAnge Navigation (LORAN) C. RNAV 5 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 5 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure . |
EN ROUTE & TERMINAL PHASES | ||
RNAV 2 All Sensors | C1 | Area Navigation (RNAV) using all available sensors. RNAV 2 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 2 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNAV 2 GNSS (GPS) | C2 | Area Navigation (RNAV) using Global Navigation Satellite System (GNSS). RNAV 2 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 2 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNAV 2 DME/DME | C3 | Area Navigation (RNAV) using Distance Measuring Equipment (DME). RNAV 2 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 2 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNAV 2 DME/DME/IRU | C4 | Area Navigation (RNAV) using Distance Measuring Equipment (DME) and Inertial Reference Unit (IRU). RNAV 2 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 2 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNAV 1 All Sensors | D1 | Area Navigation (RNAV) using all permitted sensors. RNAV 1 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 1 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNAV 1 GNSS (GPS) | D2 | Area Navigation (RNAV) using Global Navigation Satellite System (GNSS). RNAV 1 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 1 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNAV 1 DME/DME | D3 | Area Navigation (RNAV) using Distance Measuring Equipment (DME). RNAV 1 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 1 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
RNAV 1 DME/DME/IRU | D4 | Area Navigation (RNAV) using Distance Measuring Equipment (DME) and Inertial Reference Unit (IRU). RNAV 1 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 1 nautical miles. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. |
TERMINAL PHASE | ||
RNP 1 All Sensors | O1 | Required Navigation Performance (RNP) using all permitted sensors. RNP 1 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 1 nautical mile. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. RNP adds to RNAV accuracy standards by requiring onboard navigation performance monitoring and alerting. |
RNP 1 GNSS (GPS) | 02 | Required Navigation Performance (RNP) using Global Navigation Satellite System (GNSS). RNP 1 means the aircraft navigation system must be able to calculate its position to within a circle with a radius of 1 nautical mile. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. RNP adds to RNAV accuracy standards by requiring onboard navigation performance monitoring and alerting. |
RNP 1 DME/DME | 03 | Required Navigation Performance (RNP) using Distance Measuring Equipment (DME. RNAV 1 means the aircraft navigation system must be able to calculate its position to within a circle whit a radius of one nautical mile. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. RNP adds to RNAV accuracy standards by requiring onboard navigation performance monitoring and alerting. |
RNP 1 DME/DME/IRU | 04 | Required Navigation Performance (RNP) using Distance Measuring Equipment (DME) and Inertial Reference Unit (IRU) RNP 1 means the aircraft navigation system must be abel to calculate its position to within a circle with a radius of 1 nautical mile. This accuracy must be achieved at least 95% of the flight time by the aircraft operating within the airspace, route, or procedure. RNP adds to RNAV accuracy standards by requiring onboard navigation performance monitoring and alerting. |
APPROACH PHASE | ||
RNP Approach | S1 | Required Navigation Performance (RNP) Approach (APCH). GNSS (GPS) is the primary navigation system to support RNP APCH procedures. Characteristics of RNP APCH: - Straight segments , fly-by turns -Allows for two-dimensional (2-D) non-precision approach (NPA) -Allows for three-dimensional (3-D) approaches with vertical guidance |
RNP Approach with Baro VNAV | S2 | Required Navigation Performance (RNP) Approach (APCH) with Barometric Vertical Navigation (Baro-VNAV) GNSS (GPS) is the primary navigation system to support RNP APCH procedures. Characeristics of RNP APCH: - Straight segments, fly-by turns - Allows for two - dimensional (2-D) non-precision approach (NPA) - Allows for three-dimensional (3-D) approaches with vertical guidance through useof barometri, vertical navigation (baro-VNAV) |
RNP Approach with Radius to Fix (authorization required) | T1 | Required Navigation Performance (RNP) Approach (APCH) with Radius to Fix (RF) - Special Authroization Required. Like RNP APCH, GNSS (GPS) provides the primary infrastructure. It allows reduced lateral & vertical obstacle clearnace, curved paths, and precise missed approach guidance. |
RNP Approach without Radius to Fix (authorization required) | T2 | Required Navigation Performance (RNP) Approach (APCH) without Radius to Fix (RF) - Special Authroization Required. GNSS (GPS) is the primary navigation system to support RNP APCH procedures. Characteristics of RNP APCH: - Straight segments, fly-by turns - Allows for two-dimensional (2-D) non-precision approahc (NPA) - Allows for three - dimensional (3-D) approaches with vertical guidance. |
FIELD 18 OTHER INFORMATION (Only commonly used code prefixes are shown below) | ||
Information Type | Indicator | Notes |
Equipment | PBN/ | RNAV and RNP equipment codes to indicate capabilities. See ICAO PBN/RNAV-RNP table. |
Navigation | NAV/ | NAV/SBAS is entered to indicate WAAS capability and the ability to fly LPV approaches. |
Communications | COM/ | Communications capabilities not already specified in COM/NAV field. |
Data | DAT/ | Data capabilities not already specified in COM/NAV field. |
Surveillance | SUR/ | SUR/260B indicates ABS-B 1090 Mhz. SUR/282B indicates UAT capability. |
Registration | REG/ | Enter REG/##### if operating in RVSM airspace. Otherwise, enter registration markings if different from that specified in Identifier field. |
SELCAL | SEL/ | SELCAL code assigned to the aircraft. |
Type of Aircraft | TYP/ | Used if not specified in the Type field. |
Mode S Code | CODE/ | This is the aircraft Mode S code [base 16 / hex] obtained from the FAA Aircraft Registration database. |
Status | STS/ | Reason for special handling. See AFM (page 5-1-24) for list of codes. |
Departure Airport | DEP/ | When departing an airport with no ICAO code, enter ZZZZ for Departure Aerodrome and DEP/CODE (e.g. 2S7) in Field 18. |
Destination | DEST/ | When the destination is an airport with no ICAO code, enter ZZZZ for Destination Aerodrome and DEST/CODE (e.g. 2S7) in Field 18. |
Alternate Airport | ALTN/ | When the alternate airport is an airport with no ICAO code, enter ZZZZ for ALTN Aerodrome and ALTN/CODE (e.g. 2S7) in Field 18. |
NOTE: For a complete description of Flight Plan filing codes, including entries possible for Field 18, refer to the FAA Flight Planning Information Web site.
