Pairing a quatix 3 to a GNX Wind
To pair a quatix 3 with the GNX Wind you will need to use the steps below:
On GNX Wind:
  1. Press the menu button.
  2. Go to 5.0 and press the menu button.
  3. Make sure that "Enbl" is set to ON.
  4. Then go to 5.2 and press the menu button.
  5. It will say "ADD".
  6. Leave the GNX on the screen where it says "ADD."
On the quatix 3:
  1. Press the MOB button.
  2. Scroll down and select Boat Data.
  3. It should automatically pair with the GNX device as long as the steps above were completed.
 As long as you have the "Enbl" option on the GNX Wind set to on, whenever you go to Boat Data on the Quatix 3, it should automatically connect.
