Garmin Express Fails to Install or Update on a Windows Computer
When installing the Garmin Express™ software to a Windows computer, there may be obstacles that can prevent the installation from completing successfully. When this occurs, an error message such as Install Failed may display or the installer may not launch.
NOTE: If Garmin Express was installed previously, see Removing Garmin Software and Garmin Registry Keys in Windows.
Try the Following Solutions:
2. Use a Personal Computer
A personal computer is often required to successfully run Garmin Express. When installing Express on a business computer, the IT department responsible for the computer may need to be contacted as computers owned by businesses often have restrictions set up to prevent the installation of unauthorized programs.
You may get an error message that says you don't have administrative privileges if you try to install a program without being signed into an administrative account. For more information see  Administrator Password on a Windows Computer
3. Restart the Computer and Try Again
NOTE: Shutting down, pressing the power button, or closing the lid on a notebook computer may not effectively restart the computer on some operating systems. Follow the instructions below to ensure that the computer is completely restarted.
Windows 10 and Newer
    1. Right-click the Windows Icon Start button
    2. Click Power
      • Some computers may skip this step.
    3. Click Shut down or sign out
    4. Click Restart
See below for a Windows 10 example.
Windows 8.1 and 10 Restart
4. Verify the Computer Meets System Requirements for Garmin Express
WindowsMacOS/OSX
  • Windows 7 SP1 or newer, Microsoft .NET 4.5.2 (included)
  • 1024 x 768 display, USB port and 1 GB RAM
  • High speed Internet access (Not for use with dial-up, mobile or satellite connection)
  • May require up to 20 GB free disk space
  • OS X 10.10 or newer
  • 1440 x 900 display, USB port and 1 GB RAM
  • High speed Internet access (Not for use with dial-up, mobile or satellite connections)
Install the latest Microsoft Windows updates
Microsoft has released Windows updates that may resolve issues with Garmin applications.  For more information about installing these updates, see the How do I keep my PC up to date? section of Microsoft's Windows Update FAQs page:
Windows Update: FAQ
NOTE: You may receive the error message "not enough space on computer, this computer does not have enough space to download the update." To correct the error, free up space on your hard drive (C: Drive).
5. If the Installer will not Launch, Verify it is not Blocked by Windows
  1. Navigate to your downloads folder
    • You can use the search feature General Tab on your toolbar to search for "downloads"
  2. Right-click the downloaded Garmin Express Installer file
  3. Click Properties
  4. Click the Unblock button if present
    • If there is no Unblock button, the installer is not blocked
  5. Click OK
General tab
6. Run Garmin Express as an Administrator
null
7. Disable Antivirus Applications
Although most security software will not interfere with Garmin Express, some more aggressive applications such as those in a business environment (on a work computer) may cause this error. If possible, try temporarily disabling the software or try a different computer if the software can't be disabled.
8. End any Microsoft Installer Processes in Task Manager
1. Open the Task Manager by holding down Ctrl + Shift + Esc
Processes tab
  • If prompted to allow Task Manager to make changes to your computer, click Yes
2. End any processes named msiexec.exe
9. Uninstall Previously Installed Versions of Garmin Express
After the above instructions are followed, Garmin Express should be able to install successfully. If not, the computer should be checked by a Microsoft certified repair technician, or another computer should be used.
Related
