How to Improve the Garmin fenix 5 Plus and fenix 5s Plus Battery Life
If you are charging your Garmin fenix more frequent than expected, it could be due to the amount of usage or settings being used. Below is a list of functions that could cause the battery to drain faster than anticipated, for instructions on enabling or disabling these, visit the "Customizing Your Device" section in the owner's manual.
NOTE: It is important that before you address some of the functions that affected battery life, that you first make sure your watch is up to date: How to Install Software Updates to My fenix 5 Plus Series Watch
Your watch can perform a variety of functions, and any function the watch performs will require some power from the battery. Some functions, and how often you use them, will require more battery than others.
Why is My Watch Battery Draining Quickly?
If your watch has a shortened battery life, here are some troubleshooting steps we recommend.
  1. Be sure that you are on the latest software
  2. Perform a forced restart .
  3. Fully charge your watch to see if the issue has been resolved.
  4. If your watch continues to drain battery quickly, check any recently adjusted settings that could contribute to a higher battery use. For help adjusting watch settings, see the How Can I Get More Battery Life? section below.
If your battery is being used faster than expected, or not lasting as long as it used to, read the information below to learn about settings and features that have a greater impact on battery usage.
Adjust Settings
The default settings for your watch were configured to balance performance with battery life. Changed settings may be the cause of increased battery drain. If you forgot the settings you changed, you can restore the default settings for your watch. For help see, Reset Default Settings .
NOTE: Settings for the options listed below are located in the watch menu or Controls menu. Not all watches will support all listed features. Refer to your owner's manual for feature compatibility, and exact setting location.
  • LED Flashlight: Using the flashlight can reduce battery life. You can reduce the brightness to extend the life of the battery.
  • Pulse OX: Using All-Day Acclimation or During Sleep modes with the pulse oximeter will use the battery at a higher rate. To conserve battery life, it is recommended to set the acclimation mode to Manual. The watch will only analyze your oxygen saturation when you view the pulse oximeter widget.
  • Display: How bright the display is set and how often it comes on can use battery more quickly or less quickly. Having the display set at max will use a lot of battery while the display is on. Try adjusting the Display settings, and turn off Always On to find a balance for battery usage.
  • GPS: When enabled you will see a higher battery use, which is why GPS tracking is only activated during activities or navigation.
  • Music: Controlling music being played on your phone, downloading music over Wi-Fi, and playing music stored on the watch will contribute to higher battery use. We recommend charging your watch while downloading music, if it supports this feature.
  • Bluetooth: Occasional text notifications and use of other connected features will drain far less battery than continually receiving texts, answering the phone, running a music player, or getting weather updates.
  • Connected Sensors: Additional connected sensors like HRM chest straps, power meters, or Bluetooth headphones all require additional power from the watch to stay connected.
  • Watch Face: Some watch faces, apps, widgets, and data fields may draw more power depending on how many things they do or whether they use GPS positioning or not.
  • Widgets: Some widgets update data when you select them, like weather. Widgets like Altimeter, Barometer, and Compass (ABC sensors) are always active.
  1. Hold UP/MENU.
  2. Select System.
  3. Select Reset.
  4. Select Reset Default Settings.
  5. Press DOWN to select Continue.
  6. Select Yes.
If your watch is paired to your phone, you will need to pair the watch back to the phone after resetting. For help on pairing your watch to your phone, refer to your owner's manual. For additional resources on pairing your watch, see - Garmin Connect App Bluetooth Troubleshooting.
Clean Charging Contacts
Garmin recommends using a Garmin charging cable, and making sure the charging contacts on the watch and charging cable are free and clear of debris. For instructions on how to clean the charging contacts, see - Cleaning the Battery Contacts on a Rechargeable Garmin Watch.
Update Software
Make sure your watch is up to date on software. We recommend using Garmin Express to make sure your software is the most current version - Using Garmin Express to Update Your Watch's Software.
Perform a Forced Restart
This will not clear any user data or reset settings. Significant battery use can sometimes occur if an activity or another feature is left running in the background. Try the following steps to perform the restart:
  1. Hold the LIGHT button.
    NOTE: You may need to hold for up to 30 seconds.
  2. When the watch face goes blank, release LIGHT.
  3. Press LIGHT to turn the watch back on.
  4. Let the watch charge to 100% and use as normal.
  5. Track how long the battery lasts after performing the restart.
Is Your Watch Battery Still Draining Quickly?
After attempting the above troubleshooting if you still see significant battery use, we recommend contacting Product Support to help determine what is using the battery.
Some information to help Product Support determine what might be using the battery more than expected:
  • Is the display set to Always On, and is Gesture enabled?
  • How often are you performing GPS activities, and how long are they?
  • Is Pulse Ox enabled? If so, what is it set to?
  • What is the battery estimate in days on a full charge, and how fast does it take to completely drain the battery?
  • What kind of watch face are you using? Does it display current heart rate?
Some of the functions are redundant, for example; steps and activities are uploaded both through WiFi and the Bluetooth connection to the Garmin Connect Mobile application. If using the Garmin Connect Mobile app continuously, it may be a good idea to turn off the Auto Upload setting to help conserve battery power. The Storm Alert function of the Barometer when a smart phone updates local weather is another redundant battery drain.
If battery drain still continues after making some settings changes, try returning the watch to factory defaults and seeing how long the battery lasts on a full charge without pairing it to smartphone again. If the battery lasts like it used to, then the battery drain would be the result of the choice of customized settings on the watch, or Bluetooth connected features.
