Using Tracks on the Foretrex 101
The Foretrex® 101 outdoor device automatically draws an electronic breadcrumb trail or ‘track log’ on the Map Page as you travel. Tracks are marked BEGIN and END. The Foretrex 101 uses the Track Log to allow you to navigate using the saved track or using the TracBack feature.
TracBack guides you to where you started by following the track log that you left behind, allowing you to return along a traveled path without marking any waypoints. You can retrace your track in both directions. If you want to keep a record of a certain track log or use the TracBack feature, clear the Track Log before you start traveling.
To Navigate Using TracBack
Press the PAGE button to access the Main Menu.
Use the UP and DOWN arrows to highlight TRACKS and press ENTER to open the Tracks Menu Page.
Use the UP and DOWN arrows to highlight PAN & TRACBACK and press ENTER.
Use the UP and DOWN arrows to pan the track log. Press ENTER to display the Pan Options.
Use the UP and DOWN arrows to select TRACBACK and press ENTER.
The Navigation Page displays a Pointer indicating the direction to go. Follow the arrow as you would for a normal navigation.
To Clear the Track Log
From the Map Page, press ENTER to access the Map Page Options.
Use the UP and DOWN buttons to select CLEAR TRACK LOG and press ENTER
-OR-
From the Main Menu, press ENTER when TRACK is highlighted to open the Tracks Menu Page.
Use the UP and DOWN arrows to highlight CLEAR TRACK and press ENTER.
Use the UP and DOWN arrows to highlight YES on the pop-up window and press ENTER to clear the track log.
