(2015) Service Alert 1538: Operations with Altimeter Set to QFE (height above field elevation)
PRODUCTS AFFECTED:
 Garmin G900X, G950, G1000(H), G2000, G3000, G5000, Cirrus Perspective, Embraer Prodigy, and Embraer Prodigy Touch Integrated Avionics Systems are affected.
NOTE
Most locations utilize the QNH altitude that provides altitude above mean sea level.  However QFE altitude may be used in some locations (e.g. Russian Federation and the People's Republic of China).  In many locations that normally utilize QFE, the flight crew may request the QNH altimeter setting.
ISSUE:
 System functions will not operate properly with a QFE altimeter setting.
PILOT ACTION:
 Do not use a QFE altimeter setting with this system. Use only a QNH altimeter setting for height above mean sea level, or the standard pressure setting, as applicable.
