Try the steps below if your device does not display the connection screen, does not appear as a drive in Windows, or appears as an "unknown device" in the Windows Device Manager.
Try a Different USB Cable:
Mini USB Cable Micro USB Cable USB Cable Type A to Type C USB Cable Type C to Type C
Ensure That the USB Port is Working Properly:
Try a different USB port on your computer and/or test the USB port with a different USB device
Connect the cable directly to the computer. Avoid connecting through a converter cable, USB hub, USB extension cable, keyboard, or monitor
On desktop computers, use the USB ports on the back of your computer
Avoid using a PowerShare USB port
Laptop Desktop
- Check for visible signs of damage to the USB port on the device such as a loose or sagging cable connection.
Disable USB Selective Suspend
USB Selective Suspend will limit power to connected USB devices, including your Garmin device. It can potentially cause recognition problems.
Contact your computer's manufacturer for instructions to disable USB Selective Suspend.
Restart the Computer and Try Again:
NOTE: Shutting down, pressing the power button, or closing the lid on a notebook computer may not effectively restart the computer on some operating systems. Follow the instructions below to ensure that the computer is completely restarted.
Windows 10 and Newer
- Right-click the
Start button - Click Power
- Some computers may skip this step.
- Click Shut down or sign out
- Click Restart
See below for a Windows 10 example.
