- Select Layout
- Select a new layout for the data screen
NOTE: Press Back twice to exit the menu.
Editing Data Screens on the Descent Mk2 Series
The activity data screens on the Descent™ Mk2 series dive computers can be edited, reordered, or removed. This allows for customization of the data you see while in an activity, only seeing the data that is most important to you.
Opening the Edit Menu
These steps guide you to the menu where edits can be made to your data screens and data fields.
- Press Start/Stop to enter the activity list
- Select an Activity
- Press and hold Menu to open settings
- Select (Activity Name) Settings
- Select Data Screens
- Select the screen you wish to edit
You can now make changes to data screens and data fields.
Choose the option below that matches the changes you would make and continue with the steps.
- Select Data Fields
- Select a field to edit
- Select a category of data fields
- Select a data field
- Select Reorder
- Press Up or Down to reorder the data screen
- Press Start/Stop to confirm the placement
- Select Remove
- Select Yes to remove
- Select Add New
- Select the type of data for the screen to display
- Press Up or Down to reorder the new screen
- Press Start/Stop to confirm the position
Edits can now be made to the new data screen.
