Instructions to Pair a Garmin Device to a Smartphone
To establish a connection between your watch and the Garmin Connect™ app, walk through the steps below:
IMPORTANT: Do not pair your Garmin® device directly through the Bluetooth® settings of your smartphone. You must pair the device through the Garmin Connect app to establish a proper connection to your phone.
Open the Garmin Connect app.
Select More (bottom right).
Select Garmin Devices.
Select Add Device.
Select your device.
Place your Garmin device into pairing mode. This allows the Garmin Connect app to find it.
This setting is typically found under Settings > Bluetooth or Phone > Pair Mobile Device or Pair Phone. Refer to your owner's manual for specific steps.
From the Garmin Connect app select Start or Connect it.
Input or confirm the six-digit code displayed on your watch in the Garmin Connect app.
Upon completion, the Connect app will display the Home view which will provide a snapshot of the data collected by your Garmin device:
