Recording in Standard PAL 25/50 FPS Rates with the VIRB X/XE
Phase Alternating Line (PAL) is an alternate color encoding system to the National Television System Committee (NTSC). VIRB devices can record using either method1.
To select PAL or NTSC on a VIRB X or VIRB XE:
  1. Hold Menu
  2. Select System
  3. Scroll down to Format
  4. Press OK to toggle between NTSC and PAL
The VIRB will now record in the selected format.
1If your device does not have the option to switch formats, a software update may be required. For instructions on updating your device, please see VIRB X/XE Software Update.
