Advanced Sleep Monitoring Watch Compatibility
Advanced Sleep Monitoring allows users to track their sleep statistics in the Garmin Connect™ account. The feature is available on watches with an optical heart rate sensor. For more information see What is Advanced Sleep Monitoring in Garmin Connect?.
What Watches are Compatible?
Select the following to reveal a list of compatible models.
Compatible Watch List
  • Approach® S50
  • Approach® S62
  • Approach® S70 | Approach® S70 - TaylorMade® Edition
  • D2™ Air
  • D2™ Air X10
  • D2™ Charlie
  • D2™ Delta | D2™ Delta PX | D2™ Delta S
  • D2™ Mach 1 | D2™ Mach 1 Pro
  • Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
  • Descent™ G2
  • Descent™ Mk1
  • Descent™ Mk2 | Descent™ Mk2S | Descent™ Mk2i
  • Descent™ Mk3 | Descent™ Mk3i
  • Enduro | Enduro 2 | Enduro 3
  • epix (Gen 2) - Standard Edition| epix (Gen 2) - Sapphire Edition | epix (Gen 2) - Porsche Edition
  • epix Pro (Gen 2) - Standard Edition| epix Pro (Gen 2) - Sapphire Edition
  • fēnix® 5S | fēnix® 5 | fēnix® 5X
  • fēnix® 5S Plus | fēnix® 5 Plus | fēnix® 5X Plus
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner® 35
  • Forerunner® 45 | Forerunner® 45S
  • Forerunner® 55
  • Forerunner® 165 | Forerunner® 165 Music
  • Forerunner® 245 | Forerunner® 245 Music
  • Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
  • Forerunner® 265 | Forerunner® 265S
  • Forerunner® 570
  • Forerunner® 645 | Forerunner® 645 Music
  • Forerunner® 745
  • Forerunner® 935
  • Forerunner® 945 | Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Forerunner® 970
  • Garmin Swim® 2
  • Instinct® - Standard Edition | Instinct® - Tactical Edition | Instinct® - Esports Edition
  • Instinct® Solar - Standard Edition | Instinct® Solar - Camo Edition | Instinct® Solar - Surf Edition | Instinct® Solar - Tactical Edition
  • Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
  • Instinct® 3 - AMOLED | Instinct® 3 - Solar
  • Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
  • Instinct® E
  • Legacy Hero - Captain Marvel | First Avenger
  • Legacy Saga - Darth Vader | Rey
  • Lily® - Classic Edition | Lily® - Sport Edition
  • Lily® 2 | Lily® 2 Classic
  • Lily® 2 Active
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • quatix® 5 | quatix® 5 Sapphire
  • quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
  • quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
  • quatix® 7 Pro
  • tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
  • tactix® 8 - AMOLED | tactix® 8 - Solar
  • tactix® Charlie
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
  • Venu®
  • Venu® 2| Venu® 2S
  • Venu® 2 Plus
  • Venu® 3 | Venu® 3S
  • Venu® Sq | Venu® Sq Music
  • Venu® Sq 2 | Venu® Sq 2 Music
  • Venu® X1
  • vívoactive® 3 | vívoactive® 3 Music
  • vívoactive® 4 | vívoactive® 4S
  • vívoactive® 5
  • vívoactive® 6
  • vívomove® HR
  • vívomove® 3 | vívomove® 3S
  • vívomove® Luxe | vívomove® Sport
  • vívomove® Style | vívomove® Trend
  • vívosmart® 3
  • vívosmart® 4
  • vívosmart® 5
  • vívosport®
Steps to Ensure Sleep Data Accuracy
  • Put the watch on at least 2 hours before bedtime and keep it on while sleeping.
  • Ensure the watch's heart rate monitor is on, and it fits snugly but comfortably.
  • If you have more than one activity tracker, set the one with Advanced Sleep Monitoring as your Primary Wearable Device.
    NOTE: If you use the Index™ Sleep Monitor to track your sleep it doesn't need to be set as a Primary Wearable.
  • Ensure a valid birth date is saved. For instructions, see:  Changing Device and User Settings in Garmin Connect for steps to adjust the birth date.
  • Confirm your typical sleep and wake times are set correctly. See: Setting Sleep and Wake Window Times in Garmin Connect.
  • If your watch features Battery Saver, ensure it is not set to automatically enable during your scheduled sleep times, as this can interfere with sleep tracking. Refer to your owner's manual (search "Customizing Sleep Mode") for compatibility details and specific steps for your model.
See Related below for steps on adding the Sleep Widget to compatible watches and for troubleshooting sleep statistics not showing in Garmin Connect.
Related
