Please be informed that, in conjunction with the Agong's Birthday public holiday in Malaysia on Monday, 2nd June 2025, our call center services will not be available on that day. We apologize for any inconvenience caused during this brief interruption and thank you for your patience.
Garmin Catalyst Cables
The Garmin Catalyst comes with four different cables included in the box.
  • Short cable = microUSB Computer connection cable
    • Use the micro USB end to connect to the side port on the device and the USB end to connect to a computer
    • This provides the connection needed if you want to update with Garmin Express
    • The device can be updated with Wi-Fi
    • Measures 1.5 feet / .5 meters
  • Medium cable = Garmin Catalyst power cable
    • Use the mini USB end to connect to the magnetic mount and the USB end to connect to the 12-volt Socket Power Adapter plug
    • This provides power to the Garmin Catalyst
    • Measures 5 feet / 1.5 meters
  • Long cable = Remote Cam power cable
    • Use the micro USB end to connect to the Remote Cam and the USB end to connect to the magnetic mount
    • This provides power to the Remote Cam
    • Measures 11.5 feet / 3.5 meters
  • Bare Wire Power Cable = Alternate Garmin Catalyst power cable
    • Use this cable if you prefer to hardwire your device
    • The cable powers your device and is compatible with 12V and 24V systems
    • Measures 18 feet / 5.5 meters
Related
