Range Relay
The Range Relay feature on your Approach® Z30 golf laser rangefinder will send ranged distances to your paired compatible Garmin device or the Garmin Golf™ app. Once you have ranged a target with the Approach Z30 rangefinder, the distance will show on your device or in the Garmin Golf app, and the distance will automatically update as you progress through the hole. This feature is useful for blind shots, or being able to provide yardage information for other golfers without the need to laser the target again. See the Garmin Golf Science page for more information.
How to Use the Range Relay
The following steps will help you get the Range Relay function setup on your compatible Garmin device or Garmin Golf app.
For pairing the Approach Z30 rangefinder to a compatible Garmin device see your owner's manual and search "Pairing a Compatible Device".
After the Approach Z30 rangefinder is paired, start a round of golf on your compatible device.
Once your compatible device displays the first hole, wake up you Approach Z30 rangefinder by pressing the
button.
Laser the flag or desired target.
The lasered distance will show up on your compatible device with a laser range arc.
Distances will automatically update on your compatible device until you laser a new target.
Open the Garmin Golf app.
Start a Round of Golf. See Related for how to start a round of golf and how to keep score on the Garmin Golf app.
Once the Garmin Golf app displays the first hole, wake up you Approach Z30 rangefinder by pressing the
button.
The lasered distance will show up in the Garmin Golf app with a laser range arc.
Distances will automatically update in the Garmin Golf app until you laser a new target.
Range Relay Not Showing Up
If the Range Relay is not appearing on your compatible device or Garmin Golf app see the following steps.
Confirm that the Approach Z30 rangefinder shows connected on your compatible device or the Garmin Golf app.
Make sure the battery in the Approach Z30 rangefinder is good and does not need to be replaced. See your owner's manual and search "Installing the Battery".
External factors can affect the ability of the rangefinder to laser a target. For more information see your owner's manual and search for "Troubleshooting Ranging Accuracy".
Confirm the Approach Z30 rangefinder's software is up to date by syncing the device with the Garmin Golf app.
Update your compatible device or Garmin Golf app on your phone. See your owner's manual for specific steps on updating your compatible Garmin device.
