Update and Learn About Software for the Enduro
Keeping your software up to date will ensure that you get the best performance and latest features, which are listed in the What’s New? section. Methods for updating software are described below.
For information on updating compatible mapping, see Related at the bottom of the page.
What's New?
System Software April 2025 Release Notes v28.02
New Features
- Added a legal disclaimer tip message to the storm alert feature.
Continued Improvements and Bug Fixes
Fixed a UI issue on the flight paths setup feature for MARQ Aviator.
Fixed a possible issue with popularity data during routing and map drawing on fēnix 6 Pro series devices.
Fixed an issue where elevation alert would constantly tone.
Fixed an issued where notifications would sometimes be slow to pop up.
Fixed an issue where loading certain courses would cause the device to shutdown.
Miscellaneous bug fixes and improvements.
CIQ bug fixes and improvements.
Installing Software Updates
Garmin Connect™ App
The Garmin Connect app will download software updates automatically behind the scenes while your watch is connected to your mobile phone. There are no steps required for you to take to get the latest software. Generally, any released updates will take up to a week to download before automatically, or prompting, to install on your device.Search for, and download the Garmin Connect app in your phone's application store to get started. For more information on the Garmin Connect app, see - Garmin Connect app on Garmin.com.
Garmin Express™ Software
Garmin Express software provides the ability to check for, and download software updates each time you connect your device to the computer.
For information on downloading Garmin Express software and using it to update your device, see - Using Garmin Express to Update Your Watch's Software.
Manually Checking for Updates From the Watch
Your Garmin watch can check for the latest software updates while connected to the Garmin Connect App or through Wi-Fi®.
To manually check for updates, do the following:
Press and hold
UP/MENU.
Scroll to or select
Settings.
Select System.
Select Software Update.
Select Check for Updates.
While connected to Wi-Fi your watch will use it to check for updates. Otherwise checking for updates will default to using Garmin Connect.
Want Early Access to New Features or to Test New Software?
Garmin has public beta program that allows you to gain early access to new features, software updates, and bug fixes. You can find more information, and instructions for enrolling in the beta program, by visiting Enrolling in Garmin Beta Software Program.Benefits to enrolling:
- Early access to new features and bug fixes.
- Access to dedicated forum community for discussing beta software and bug reports.
- Ability to provide direct feedback about products or features you are passionate about.
