Garmin Dash Cam Not Recording or Missing Video
Follow the steps below if saved or unsaved footage cannot be found on your Garmin Dash Cam™ driving recorder, the Garmin Drive™ app, or the device's microSD card:
Make sure that the microSD card is inserted all the way into the Garmin Dash Cam device. If it is not, the Garmin Drive app and the device will display an error message. It is easiest to use a fingernail to press the microSD card into the slot at the bottom of the device until a click is heard.
NOTE: microSD memory cards are not included with some Garmin Dash Cam devices. The 'In The Box' and 'Specs' tabs under the product page on www.garmin.com will advise which model(s) include them.
The dash cam cannot record video if connected to a computer.
Some dash cams cannot record video when the Gallery is open on the dash cam. Exit the Gallery. It is not sufficient to switch to a different app; the device will remain in sharing mode unless the gallery or the app itself is closed.
Dash cams cannot record video if the device is exporting video with the Garmin Drive app.
The dash cam is recording if the LED in the lower-left corner is solid red, (or in the lower-right on the Garmin Dash Cam X110, Garmin Dash Cam X210, Garmin Dash Cam X310, Garmin Dash Cam Live).
Unsaved footage may be missing from the device's Gallery, the Garmin Drive app, or the microSD card when plugged into a computer to view the files. Setting the device to promptly delete unsaved footage when powered down can cause this. This setting extends the life of the microSD card but removes the footage of your drive.
To Check the Unsaved Videos Setting on the Dash Cam:
On the dash cam, go to Settings
Select Camera
Select Unsaved Videos or Temporary Videos
Select Delete When Full if the Unsaved Videos are currently set to Promptly Delete
Press the back button to save changes
The device will now continue to write unsaved footage to the microSD card until the card is filled. Older footage will then be overwritten.
To see how much footage microSD cards can hold go to Garmin Support Center for your dash cam. Search Recording Modes, Video Resolutions, and File Sizes
Check Event Detection Settings
If the dash cam device is not saving video of events (e.g. collisions or sudden stops), Event Detection or Incident Detection may be disabled.
Ensure the Device and Garmin Drive App are up to Date
The software of your Garmin Dash Cam device can be updated using either the Garmin Drive app on a smartphone or Garmin Express on a computer. See below for instructions.
