Using Loc8 Codes on Compatible Automotive Devices
Loc8 Codes are a variation of postal codes used in the Republic of Ireland. Instead of covering a general area like postal codes do, Loc8 Codes reference a specific point, much like geographic coordinates. For more information about what Loc8 Codes are and how they work, see the FAQ Loc8 Feature on Automotive Devices.
If you plan to travel to Ireland and have the appropriate map installed, you may order the Loc8 Codes download free of charge on our website, then use the Garmin Express™ application to add them to your device.
Devices must have detailed coverage for Ireland to receive turn-by-turn directions to a Loc8 Code. If needed, you may view and purchase mapping that covers Ireland from the page below:
To Download Loc8 Codes to Your Device With Garmin Express:
  1. Connect the device to a computer with a USB cable
  2. Open Garmin Express
  3. Select your device
    • If you have not yet added your device to Garmin Express, click Add a Device and follow the steps on the screen.
  4. Click Tools & Content
  5. Click the Purchased tab
  6. Click Sign In to sign in to your Garmin account
  7. Loc8 Codes should be displayed here with the message Ready to Activate. Click the  download icon.
  8. Sign in to your Garmin account again
  9. Click Continue
The installation of the Loc8 Codes should now be complete.
When using Loc8 Codes, you must set your device to a European locale (if it is not already) by performing a system restore. Please note that this will reset all user settings on your device to factory default, but your saved and recently found places will not be affected.
To Change the Locale on Your Device:
  1. Touch Settings
  2. Touch the  menu icon
  3. Touch Restore
  4. Touch Yes
  5. Select any European locale (e.g. United Kingdom, Ireland, etc.)
  6. Touch OK
After downloading Loc8 Codes for a compatible device, you can look them up by doing a basic address search.
To Search for a Loc8 Code:
  1. Touch Where To? or Search
  2. Touch Address
  3. Touch Enter Postal Code
    • Enter the desired Loc8 Code and touch Done. These can be provided by business or individuals; they may also be looked up at http://www.myloc8ion.com/.
  4. Touch Go
The device will route you to the designated location, provided you have detailed mapping for Ireland.
For more information on how to search via ZIP or Postal code, see the FAQ Searching for an Address by the ZIP Code on an Automotive Device.
