Getting Started With the Rino 750, 750t, or 755t
Below is a list of articles that will help you get started with, and get the most out of, your new Rino® 750, 750t, or 755t outdoor radio and GPS.
How Do I Get Started?
First, we recommend that you fully charge your Rino handheld (see - Charging the Battery Pack).
  1. Power on the Rino handheld by holding Power Button on the side.
    Learn More About the Touchscreen and Buttons
    Rino 750 Button Layout
    ONE WIDGETS
    TWO CALL KEY
    Rino Call Key
    • Select to transmit an attention tone on the current channel.
    • Hold to send an emergency alert to all Rino users on the current channel and code (Emergency Alerts).
    • You can customize the function of this key (Customizing the Keys).
    THREE POWER KEY
    Power Button
    • Short press to adjust the backlight.
    • Press and hold to turn the device on.
    • Press and hold until you see power icon to turn the device off.
    FOUR PTT (PUSH-TO-TALK)
    • Hold to transmit on the current radio channel (Transmitting).
    five instruction MAIN MENU
    SIX VOLUME KEYS
    • Select to adjust the volume.
    SEVEN APP DRAWER
    Rino App Drawer
    • Swipe up to open additional apps, settings, and menu items.
  2. Select your language from the list.
  3. OPTIONAL: Pair your Rino handheld with the Garmin Connect™ app on a smartphone for additional Connected Features. For pairing instructions, see - Pairing Your Smartphone.
Learn More About the Rino 750, 750t, and 755t Handhelds
The following articles will help you explore and use the many features of the Rino 750, 750t, and 755t handhelds.
Communication Features
Waypoints, Tracking, and Navigation
Connected Features
NOTE: Before leaving for a trip, ensure that you are signed into the Garmin Connect app and that the Rino handheld shows as connected in the app when it is powered on and within Bluetooth range.
Battery and Charging Features
Other Helpful Tips
