My inReach Messenger is in the Wrong Language
If your inReach Messenger device is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language.
Changing the Language
You may receive prompts to pair and activate before being able to access other settings on the inReach Messenger device. If this occurs, scroll to and select the second option in each of these prompts to skip pairing and activation, then proceed with the steps below. Pairing and activation can be completed later in Settings.
  1. If necessary, press and hold Left Arrow Button to get to the home screen:
    inReach Messenger Home Screen
  2. Press Left Arrow Button or Right Arrow Button to scroll through the main menu and select Wrench.
  3. Select Gear Wheel.
  4. Press Right Arrow Button three times, then press OK.
  5. Scroll to and select the desired language.
