Using the GHP 10 Autopilot without connecting it to a tach source from the engines
Garmin strongly recommends that a tachometer source be connected in order to scale rudder activity to levels appropriate for the current boat speed. Some boats, that cannot reach planing speeds, may not need to have the tach wires connected.
In instances where the tach information is not available for the GHP 10 autopilot, with the latest operating software installed in the GHP 10, you can choose to use GPS speed as a speed source option instead of the tach information. For instructions on how to update the GHP 10 autopilot, please refer to the related content.
To change the speed source between Tach and GPS Speed, please follow these instructions:
- With the autopilot powered ON, press the Menu button
- Choose Setup
- Choose Dealer Autopilot Config
- If Dealer Autopilot Config is not an option, press the Menu button
- Choose Setup
- Choose System
- Choose System Information
- Press and hold the Center Soft Key button for 5 seconds until Dealer Mode appears
- Press the Back button
- Choose Speed Source Setup
- Choose RPM Source, at this point, you will be provided with the following sources of Speed Information
- NMEA 2000 (Tach information from a NMEA 2000 compatible engine)
- Both (Analog tach information from both a port and starboard engine)
- Port (Analog tach information from only the Port engine)
- Starboard (Analog tach information from only the Starboard engine)
- GPS (Speed information from a directly connected chartplotter)
- None (No tach or speed information available)
For more information on the GHP 10 and connecting tach wires to it, please visit the Installation Guide for the GHP 10.
