(2022) Service Bulletin 22042 Rev A: GI 275 Multi-function Instrument System Software Version 2.50
PRODUCTS AFFECTED:
Garmin GI 275 Multi-function Instruments with System Software Version 2.42 or earlier are affected.
CERTIFICATION AUTHORIZATION:
TSO Authorization
TSO Authorization does not provide installation airworthiness approval. Separate installation airworthiness approval is required for type-certified aircraft. Notification of revision to any Garmin STC(s) will be provided under a separate service bulletin.
COMPLIANCE:
Recommended: Compliance with Garmin Service Bulletin 22042 is recommended at the next scheduled maintenance interval.
PURPOSE:
GI 275 Multi-function Instrument System Software Version 2.50 provides the following updates:
- Addresses Garmin Service Advisory 21138 for depicting FIS-B from a GNX™ 375
- Allows multiple vertical modes to be armed with a GFC 500
- Improves the GI 275 database update user experience
- Adds new FIS-B product depiction such as:
- Turbulence
- G-AIRMETS
- Icing
- Lightning
- Cloud Tops
- CWA
- Additional interface enhancements:
- Allows the VFR GPS to provide GPS NAV aiding to the GMC 507 when interfaced to Navigational sources such as the GNC® 255
- Allows the VFR GPS to provide Direct-To capability if the certified GPS source never acquires GPS
- Additional display enhancements:
- Provides a configuration option to depict Selected Course on the ADI page
- Provides a configuration to change the ADI aircraft symbol between the standard flat bar (dual cue) style depiction or the chevron (single cue) style depiction.
- Allows the display of MACH
- Provides an improved depiction of the Baro setting by inversing the background of the window when the synchronized Baro setting is being modified by the off-side display source
