Creating a Route Using Auto Guidance+ Technology Within the Navionics Boating App
NOTE: When creating your first automatic route, you will be asked to check your boat settings, which default to maximum draft and height values if you have not changed it previously (Menu > Name/Me > Boat).
To create a route using Auto Guidance+™1 technology, do the following:
  1. Select Route.
  2. Select Automatic.
  3. Choose your starting point using one of these methods:
    1. Tap a point on the map to create your Start point
    2. Tap on the starting point box and select the option for Current Position at the top.
    3. Tap on the starting point box to search by Category, entering a Lat/Long or by entering a search term.
  4. Choose your destination using one of these methods:
    1. Tap a point on the map to select your destination.
    2. Tap on the destination box to search by Category, entering a Lat/Long or by entering a search term.
      Once both points are selected, the route will be planned automatically.
      You can add or move route points at any time while the route is active by pressing on the route line to create a new point and drag it to the position you want it. You can also delete points by tapping on one and selecting Delete Waypoint.
  5. Tap SAVE to save the route without starting navigation.
    -or-
    Tap the GO button to save your route and start navigation.
  6. To close out of an active route, select Route > Stop.
1 Auto Guidance+ is for planning purposes only and does not replace safe navigation operations.
Related
