An active Bluetooth connection is required for the inReach device and the Garmin Messenger app to work together. If Bluetooth has been disabled, or a connection disruption is experienced, many of the functions with in the Garmin Messenger app will stop working.
Bluetooth Status on the inReach Device
Press MENU twice to access the main menu.
Select Setup.
Select Bluetooth.
Ensure Status is toggled on.
If necessary, press and hold
to reach the home page.
Press
or
to scroll through the main menu and select SETTINGS
Select Phone
Ensure Bluetooth Status is set to On.
If necessary, press and hold OK to reach the home page.
Press
or
Select Phone
- Ensure Bluetooth Status is set to On.
If necessary, press
until you reach the home page:
From the home page, press OK to open the main menu.
Select
Settings.
Select
Phone.
Select Status to toggle Bluetooth on.
Status will show as Connected or Waiting for Phone when Bluetooth is enabled.
Select
Select Setup.
Select Phone.
Bluetooth Status on Phone
Bluetooth should remain enabled on the paired phone to stay connected with the inReach device.
Check in the settings of the phone to confirm Bluetooth is on.
For assistance, consult the phone manufacturer.
Ensure Bluetooth is enabled if using Airplane mode.
Confirm the Garmin product appears on the phone's list of connected devices and is Connected.
Check Connection Status in the Garmin Messenger App
Open the Garmin Messenger app.
Select Device.
NOTE: If this option is not available, the inReach device will need to be paired with the app.
View the connection status.
