VHF Feature Matrix
Product | Fist Mic | Remote Station(s)(GHS 11 and Active Speaker) | External Speakers | Hailer and Foghorn | GPS3 |
VHF 110 VHF 110i | Fixed | Not Supported | 4W 4 Ohm (Passive) | Not Supported | NMEA 2000 / NMEA 0183 |
VHF 115 VHF 115i | Fixed | Not Supported | 4W 4 Ohm (Passive) | Not Supported | NMEA 2000 / NMEA 0183, Built-in, or Optional GA-38 |
VHF 2101 VHF 210i VHF 210 AIS VHF 210i AIS | Removable | One Supported | Drives External Passive or Active Speaker4 | Supported2 | NMEA 2000 / NMEA 0183 |
VHF 2151 VHF 215i VHF 215 AIS VHF 215i AIS | Removable | One Supported | Drives External Passive or Active Speaker4 | Supported2 | NMEA 2000 / NMEA 0183, Built-in, or Optional GA-38 |
VHF 315 VHF 315i | Not Supported | One Included Three Supported | Up to 3 Active Speakers4 | Supported2 | NMEA 2000 / NMEA 0183, Built-in, or Optional GA-38 |
1 AIS Version Equipped with Integrated Class B AIS Receiver for Listen Only
2 Hailer Foghorn Supported Output: 22W @ 4 Ohms
3 Units with built-in GPS also support the external GA-38GPS
4 Active Speaker requires a GHS 11
NOTE: The foghorn can be setup to go off automatically, manually, and the frequency can be adjusted. Information for this can be found in the owner’s manual.
- https://www8.garmin.com/manuals/webhelp/vhf115215/EN-US/GUID-8454DF5E-F468-4748-9172-EEF6772C3CA9.html
- https://www8.garmin.com/manuals/webhelp/vhf115215/EN-US/VHF_110-115-210-215_OM_EN-US.pdf
Microphone Setup Examples
Fist Mic attached to front, 2nd Fist Mic attached to rear
Fist Mic attached to Front, GHS 11 attached to rear
