Updating Automotive Maps and Software with Garmin Express on a Tread Device
Garmin Express™ is computer software used to download and install the latest version of maps and software to your device.  Map updates are released at least once per year.
See the videos and instructions below to install and use Garmin Express to update your device.
Map Updates - Map updates provide the latest changes to roads and locations on the map used by your navigation device. The map files are large because they contain detailed information. These take longer to install.
Software Updates - Software updates make changes to the operating system files. These smaller files usually download in a few minutes. Garmin Express may alert you to reboot your device after a software update. This may be required before the map update can be installed.
Current Map Version: 2026.10 (North America) as of February 12, 2025.
Watch one of our video tutorials about installing and using Garmin Express. They are a quick and easy way to learn how to use Garmin Express.
Windows
Mac
Click the Steps Below for Written Instructions:
If you already have Garmin Express installed on your computer, skip to step 2.
1. Download and Install Garmin Express
Before updating your device, you will need to download and install Garmin Express onto your computer. See How Do I Install Garmin Express Software?. You can also update with Wi-Fi. See your owner's manual for instructions.
Download Garmin Express Software for Windows
    • Windows 10 or newer
    • Microsoft .NET 4.7.2 (included in the download)
    • 1024 x 768 display
    • USB port
    • 1 GB RAM
    • High-speed Internet access (not for use with dial-up, mobile, or satellite connections)
    • Up to 20 GB free disk space
    • For users running Windows 8 or older, please download version 7 of Garmin Express for Windows.
Download Garmin Express Software for Mac
    • OS X 11 or newer
    • 1440 x 900 display
    • USB port
    • 1 GB RAM
    • For users running OS X 10.16 or older, please download 7.18.x of Garmin Express for Mac.
See the links below for help finding the download file on your computer:
2. Connect the Device to a Computer
Connect your Garmin device to the computer with the included USB cable.
See Types of USB Cables Used to Connect Automotive Devices to the Computer to find out what cable you need.
Desktop:
usb cable plugged into desktop
Laptop:
usb cable plugged into laptop
Entering File Transfer Mode on the Tread® and Tread® - Base Edition GPS Navigators
1. Select Tap to Connect to Computer
  • If you do not select Tap to Connect to Computer this choice will eventually go away, you will then need to select Settings first.
2. Select Continue
You should now see the connection icon.
The device needs to charge if it only shows a Garmin logo with the battery icon. Charge the device using the vehicle power cable or an AC Adapter. See Using Third-Party AC Chargers, Cables, and Other Accessories with Garmin Automotive Devices.
NOTE: It is recommended to place the unit screen side down when it's plugged into the computer to reduce stress on the device’s USB port.
3. Launch Garmin Express
Garmin Express will launch during the installation.
To Open Garmin Express Manually:
Windows: Use one of the following methods (examples from Windows 10 pictured).
  • Double-click the Express icon in the system tray:
Red box around icon
  • Search for Garmin Express in the Start menu:
Red box around Garmin Express
  • Double-click the desktop shortcut:
Red box around icon
Mac: Launch Garmin Express from the Applications folder in Finder (example pictured from macOS 10.13.6). The location of the Red box around applications Finder icon may vary depending on the position of the Dock.
Garmin express screen
4. Begin Updates
1. Click on your device. The green dot means Garmin Express recognizes the device
2. Click Add a Device and follow the on-screen steps to add a new device
Garmin Express Add a Device screen
3. A message may appear asking if you want to replace the first device if you're adding a second device of the same model.
Select Yes if this is a replacement device.
Select No if you have two devices of the same model.
Garmin Express will display the updates. Your device may have a software update available, a map update available, or both. You will have an option to “Update Software,” “Update Maps,” “Install,” or “Install All.” Each path begins with this selection.
NOTE: Your device may require a software update before installing a new map. In this case, the software update will be installed before returning you to this screen where you will then have the option to “Install All” or “Update Maps.”
4. Click Update Software, Update Maps, Install, or Install All
Clicking View Details allows you to see a list of available updates and install them individually.
Garmin recommends clicking the option in the blue button to ensure all updates are installed.
  • iOverlander updates can be installed by clicking Install All.
    • Only compatible with the RV 780, RV 785, RV 890, RV 1090, and zūmo® XT GPS navigators.
5. Read the notes and click Continue
Garmin Express will display the current progress.
6. You may be prompted to restart your device if software updates are installed. Garmin Express will display instructions.
7. Click Install All or Update Maps if you have a map update available.
8. Read the Terms and Conditions and click Accept
9. Read the notes and click Continue
Garmin Express will display the Map Update progress.
An “Updates complete” message will appear when the map update finishes.
Note: Disconnecting the device or shutting down the computer before the update completes will cause an error and may make the device unusable.
Space Issues when Installing Map Updates
Use a Memory Card (Recommended) - In situations where a Garmin device does not have sufficient internal storage space to load the full coverage of a City Navigator NT map update, Garmin Express allows the maps to be installed to a microSD/SD card.
When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, see the FAQ SD Memory Card Sizes for Automotive Devices.
Adding a memory card to a compatible device will help to give it enough storage space for the entire map. For more information about using a memory card for map updates, including SD card size requirements and instructions if Garmin Express does not offer a memory card option, see Garmin Express Prompts to "Use A Memory Card (Recommended)".
If you select Use a Memory Card, the card must be inserted into the device, not the computer. The map file will be deleted from the device's internal storage drive; therefore, the memory card must remain inside the device at all times both during and after the map update.
Having Problems?
Try These Helpful Troubleshooting Links:
    • Arctic Cat G8 Display
    • Camper 780 & Traffic caravan and motorhome sat nav
    • Camper 785 & Traffic caravan and motorhome sat nav with camera
    • Camper 795 caravan and motorhome sat nav
    • Camper 890 caravan and motorhome sat nav
    • Camper 895 caravan and motorhome sat nav
    • Camper 1090 caravan and motorhome sat nav
    • Camper 1095 caravan and motorhome sat nav
    • CamperCam 795 motorhome sat nav with built-in dash cam
    • CamperVan caravan and motorhome sat nav
    • dēzl™ 780LMT-S GPS navigator
    • dezl™ LGV500 and dēzl™ OTR500 GPS navigators
    • dēzl™ LGV610 and dēzl™ OTR610 GPS navigators
    • dēzl™ LGV620 and dēzl™ OTR620 GPS navigators
    • dēzl™ LGV700 and dēzl™ OTR700 GPS navigators
    • dēzl™ LGV710 and dēzl™ OTR710 GPS navigators
    • dēzl™ LGV720 and dēzl™ OTR720 GPS navigators
    • dēzlCam™ LGV710 and dēzlCam™ OTR710 GPS navigators with camera
    • dēzlCam™ LGV725 and dēzlCam™ OTR725 GPS navigators with camera
    • dēzl™ LGV800 and dēzl™ OTR800 GPS navigators
    • dēzl™ LGV810 and dēzl™ OTR810 GPS navigators
    • dēzl™ LGV820 and dēzl™ OTR820 GPS navigators
    • dēzl™ LGV1000 and dēzl™ OTR1000 GPS navigators
    • dēzl™ LGV1010 and dēzl™ OTR1010 GPS navigators
    • dēzl™ LGV1020 and dēzl™ OTR1020 GPS navigators
    • dēzlCam™ 785 LMT-S GPS navigator with camera
    • Garmin Catalyst™ Driving Performance Optimizer
    • Garmin Drive™ 53, Garmin Drive™ 53 & Traffic, and Garmin Drive™ 53 & Live Traffic GPS navigators
    • Garmin DriveCam™ 76 GPS navigator with camera
    • Garmin DriveSmart™ 55 & Traffic GPS navigator
    • Garmin DriveSmart™ 65 & Traffic GPS navigator
    • Garmin DriveSmart™ 65 with Amazon Alexa GPS navigator
    • Garmin DriveSmart™ 65 Traveler's Edition GPS navigator
    • Garmin DriveSmart™ 66 GPS navigator
    • Garmin DriveSmart™ 71 GPS navigator
    • Garmin DriveSmart™ 76 GPS navigator
    • Garmin DriveSmart™ 86 GPS navigator
    • Kawasaki RIDGE 8" Tread Display
    • Overlander® GPS navigator
    • RV 780 & Traffic RV navigator
    • RV 785 & Traffic RV navigator with camera
    • RV 795 RV navigator
    • RV 890 RV navigator
    • RV 895 RV navigator
    • RV 1090 RV navigator
    • RV 1095 RV navigator
    • RVcam 795 navigator with built-in dash cam
    • Tread®, Tread® - Base Edition, Tread® 2, Tread® - Overland Edition, Tread® XL - Overland Edition, Tread® - SxS Edition, Tread® XL - Baja Chase Edition, and Tread® XL - Baja Race Edition GPS navigators
    • zūmo® XT and zūmo® XT2 GPS navigators
Related
