Entering coordinates on a color display eTrex
The eTrex color-screen models comes with the ability to manually enter in the coordinates for a waypoint.
To manually enter in coordinates:
- Press and hold thumbstick until Mark Waypoint page appears
- Select Location box
- Enter desired coordinates using numeric keypad
- Select OK once desired coordinates are entered
- Select OK
Once you perform step #5, the waypoint with the desired coordinates will be saved.
The waypoint can be found by accessing the Find menu from the device's Main menu.
