Share Routes and Saved Locations via Memory Card (SD Card) with a BMW Motorrad Navigator V and VI
Routes and Saved locations can easily be shared using a microSD card with BMW Motorrad Navigator V and Navigator VI devices.
To share routes with a memory card
1. Touch Apps
2. Touch Trip Planner
3. Select the route you want to share
4. Touch menu bars (3 lines) in the top left corner
5. Touch Share
6. Touch Memory Card
7. Touch OK
8. Remove the memory card and insert it into another Motorrad device
9. Touch Apps
10. Touch Trip Planner
11. Press the menu bars (3 lines) in the upper left corner
12. Touch Import
13. Select the route you want to import
14. Touch Import
The route(s) will now be imported to the device
To share saved locations with memory card
1. Touch Where To?
2. Touch Saved
3. Touch the menu bars (3 lines) in the upper left corner
4. Touch Share
5. Touch Memory Card
6. Touch the saved location you want to share
7. Touch Done
8. Touch OK
9. Remove the memory card and insert it into another Motorrad device
10. Touch Where To?
11. Touch Saved
12. Touch the menu bars (3 lines) in the upper left corner
13. Touch Import
14. Touch the shared saved locations you want to import
15. Touch Import
The Saved location(s) will now be imported to the device.
