Log in to the Garmin Explore website.
NOTE: A Garmin Explore account is required to log in.
Select Map.
Click
from the top right corner of the map.
Select Import As Routes.
Select a Collection or Library to import the files into. Then select Next.
Drag files to the import box, or choose Click Here to browse the computer for the files to import.
Once the file has been uploaded, select Import. A green check-mark will appear after the import is successful.
Uploading and Syncing GPX Files to an inReach Device
If you have GPX files for routes or waypoints that you would like to use with your inReach® satellite communicator, these files can be used by uploading them to the Garmin Explore™ website and then syncing them to the inReach device. The steps below can be used for the following inReach devices:
inReach Explorer®
inReach Explorer® +
inReach® Mini
inReach SE® +
For other inReach models, see Related .
2. Syncing the Handheld
Routes and waypoints can be synced to the inReach device by using the inReach Sync desktop app on a computer or by using the Earthmate® app on a paired mobile device.
NOTE: For more detailed steps on how to install and use inReach Sync, see - Updating inReach Firmware and Syncing Account Changes with inReach Sync.
Installing inReach Sync
Sign in at explore.garmin.com using a computer.
Select PLANS & DEVICES from the top of the page.
Select Sync & Update.
Under InReach Sync Desktop App, select Windows or Mac to start the download.
Locate the download on your computer and open it.
Follow onscreen prompts to complete installation.
Using inReach Sync
Plug the inReach device into the computer.
Launch inReach Sync from the computer.
TIP: Login if requested. Use the same email and password the device is associated with. Opening inReach Sync on a Windows or Mac Computer
inReach Sync should automatically detect your inReach device and begin syncing.
If your inReach device is not automatically connected, try using a different USB cable.Close inReach Sync when the sync completes.
When the Earthmate app is opened or refreshed, it automatically syncs between the Garmin Explore website and the paired inReach device when it is powered on. It can take a few moments for both to complete.
Syncs can also be performed manually with the steps below.
Important Notes
Ensure the same account is logged into on the Earthmate app that is also used on the Garmin Explore website.
Your inReach handheld must be paired with the Earthmate app for items to sync properly. For instructions, see - Pairing Instructions for Earthmate Compatible inReach Devices.
The paired mobile device needs a data connection to sync to and from the Garmin Explore website.
To sync to and from the Earthmate app, the inReach device needs to be powered on and in range (about 10ft) of the paired mobile device.
Syncing Manually
Open the Earthmate app.
Select
(Android™) or More (iPhone®/iPad®).
Select Account & Sync.
NOTE: You may need to to add an account to sync. If so, follow the prompts to sign in and input the email and password that you use on explore.garmin.com.
Select Sync.
A spinning circle will appear to indicate it is syncing, and then disappear when the sync is complete.
Make sure to repeat this process every time a change is made to the data stored at explore.garmin.com, on the inReach, or the Earthmate app.
Android is a trademark of Google LLC.
iPhone, iPad, and Apple are trademarks of Apple Inc., registered in the U.S. and other countries.
3. Accessing the New Data on the inReach Device
After syncing the inReach device, the newly added data can be found by accessing one of the navigation options.
inReach Explorer, inReach Explorer+, or inReach SE+
Select Routes or Waypoints from the home page.
