Using a Titleist RCT Ball With the Approach R10
The Garmin Approach® R10 launch monitor will support use of the Titleist RCT ball. Titleist RCT balls feature embedded radar reflective technology and are designed to enhance data capture for indoor conditions. When hitting a Titleist RCT ball, a minimum distance of 8 feet from the net is required.
Benefits of Using an RCT Ball
Titleist RCT balls use Radar Capture Technology to improve indoor distance accuracy and more effectively measure spin rate.  With a minimum of at least 2 full rotations, the RCT ball has a 99% signal capture rate, delivering true spin rate capture versus an estimate.
What Is Needed?
Getting The Best Results
The distance from tee to net, ball speed, and how fast the ball is spinning affect the Approach R10 monitor’s ability to measure the spin rate. While at least 2 full rotations of the ball are needed before it hits the net to get the most reliable results, it is possible for the Approach R10 monitor to measure spin with fewer than 2 rotations. However, if there was not enough spin for signal capture, the Approach R10 monitor will estimate spin. At minimum you will need 8 feet from tee to net, but may need additional range up to 20 feet. The examples below can help determine if your Approach R10 monitor is showing an estimate, and the distance needed to capture at least 2 rotations.
Determining Distance From Tee to Net
Use the chart below to help determine distance from the tee to achieve enough ball speed for a minimum of 2 rotations.
Chart with numbers in columns
How to Tell if the Approach R10 Monitor is Providing an Estimate
When viewing the Garmin Golf™ App driving range stats, if you see the ball spin rate as italic the Approach monitor is providing an estimate. You may need to increase the distance from tee to net for the Approach R10 monitor to capture enough ball spin.
Numbers of golf statistics
I Do Not See Attack Angle or Spin Axis
If are not seeing club angles in the Garmin Golf App for high spin, low smash factor shots it is possible that the signal from the RCT ball is interfering with the signal from the club.  You may need to use a standard golf ball if club metrics are what you are most interested in that case.
Example:
Additional Resources
Related
