The Varia RTL515 and RTL510 software can be updated via an Edge cycling computer or Garmin Express.
Updating the Varia RTL Software With Your Edge Cycling Computer
Your Varia Radar must be paired with your Edge device to receive software updates. Your Edge device must be registered to a Garmin Connect account and paired to the Garmin Connect app.
Power on both your Varia Radar and Edge cycling computer.
Sync your Edge with the Garmin Connect app.
Bring the Edge device within 3 m (10 ft.) of the Varia.
When new software is available, your Edge will alert you to install the software update.
Follow the on-screen instructions on your Edge to install the update.
The Varia Radar status LED flashes blue and green to indicate the device is updating software. When the update is complete, the status LED flashes green twenty times.
Updating the Varia RTL Software Using the Garmin Express Application
Before you can update your device software, you must download the Garmin Express application.
You can update Varia software using the Garmin Express application.
Connect your Varia Radar to your computer using the USB cable.
Open the Garmin Express application on your computer.
Follow the on-screen instructions in Garmin Express.
- Once your Varia Radar has finished syncing with Garmin Express, unplug it from your computer.
