Sending a Check-In/Preset Message From the Montana 700i or 750i
Check-In Messages (formerly known as Preset Messages) are found at the Garmin Explore™ website and have predefined text and recipients.1
While sending one of these messages does not count against your monthly inReach message allotment, replies will.
Sending a Check-In/Preset Message With the Montana® 700i or 750i Outdoor Handheld
If you have recently made changes to your Check-In (or Preset) messages, it is important to sync your Garmin device to ensure it has the latest version of these messages.
Select
to access the main menu.
Select
Select Messages.
Select Send Preset or Send Check-In.
Select which message you wish to send.
Select Send Message.
The selected message will be sent. Make sure you have a clear view of the sky to ensure the message is sent.
1 Check-in messages have replaced preset messages as of September 27th, 2022. inReach® accounts set up prior to this date will still have preset messages available, but any new accounts created after this date will use check-in messages. For more information on customizing your check-in/preset messages, see - Editing inReach Preset Messages on the Garmin Explore Website or Editing inReach Check-In Messages on the Garmin Explore Website.
