How to Configure the Garmin Boat Switch Livewell Pump Cycle Duration
The Garmin Boat Switch livewell duration can be set to 1, 3, 5, 7, 9, 11, 13 or 15 minutes. By default the duration time is 5 minutes when activated. Connecting the SWITCH INPUT: LIVEWELL CYCLE ADJ wire to a common ground for three seconds changes the runtime to the next highest. The screen will display the new runtime. When set to the maximum of 15 minutes, connecting the SWITCH INPUT: LIVEWELL CYCLE ADJ wire to common ground for three seconds cycles it back to 1 minute.
