Taking and Retrieving a Screenshot on an Alpha 200 Plus or Alpha 300 Series Dog Tracking Handheld
It is possible for your Alpha® 200 Plus or Alpha® 300 series dog tracking handheld to take a screenshot of what is currently displayed on the screen. Similar to smartphone screenshots, this can be helpful for sharing what you saw on a screen with others, or if requested by Product Support for troubleshooting.
In order to activate this feature, you first need to enable Screen Capture. Steps for this and retrieving the screenshots can be found below.
Enabling Screen Capture
  1. Select Setup from the Main Menu
  2. Select Display
  3. Select Screen Capture
  4. Select On
Once turned on, you can take a screen shot of any screen by quickly pressing Power.
This screen will display when the Screen Capture feature is turned on:
Press power key to capture screenshot message
NOTE: The Screen Capture feature will need to be enabled every time the device is powered on and you would like to take take screenshots.
Retrieving the Screenshots
The screenshots can be viewed and retrieved when the device is connected to the computer.
  1. Connect the device to the computer via the USB cable
  2. Select the Garmin drive
  3. Select the Garmin folder
  4. Select the Scrn folder
All of the screenshots taken on the device will now appear.
