Popular Truck Paths
You can enable your device to highlight popular truck paths on the map. This can be useful to help you choose roads more accessible for your vehicle.
  • These paths will be highlighted in purple
  • Helps drivers avoid narrow streets with tight turns
  • Content is updated with new maps
  • These truck paths are not STAA or TD Preferred routes
  • The data is gathered from anonymous drive logs
  • Line weight is based on popularity determined by the percentage of drivers taking these roads
Touch the Popular Truck Paths icon on the map screen to enable/disable this feature.
If the popular truck path icon is missing from the map screen it can be added to the screen.
Add the Popular Truck Path Icon
1. Touch View Map
2. Touch the Map Tools Icon  Map Tools Icon Older
3. Touch the Wrench
4. Touch the Plus icon
5. Select Popular Truck Paths
6. Touch Save
