How Do I Change the Battery on the Garmin Foot Pod?
When you receive a battery low message on the watch your Foot Pod is paired to, your Foot Pod has approximately five hours of battery life remaining. To replace the battery, follow the instructions below.
WARNING: Do not use a sharp object to remove the user-replaceable batteries. Contact your local waste disposal department to properly recycle the batteries.
Locate the circular battery cover on the back of the Foot Pod.
Twist the cover counter-clockwise to unlock it.
Remove the cover and the battery.
Place the new CR2032 battery into the cover with the positive side facing inside the cover.
Replace the cover by aligning the dots to unlock, then rotate clockwise to the lock position as shown below:
