Round Trip Routing on the GPSMAP 66/67 Series
The Round Trip Routing feature on the GPSMAP 66/67 series allows the user create a looped route based on starting location and estimated distance. It will calculate a looped route navigating on roads or trails. A routable map must be installed on the handheld for this feature to work. To start a Round-Trip route, follow the steps below.
Starting a Round-Trip Route
  1. With the handheld powered on, press FIND.
  2. Select Round-Trip Routing.
  3. Input a desired distance and location.
  4. The handheld will now generate a list of 3 routes.
  5. Select a route to view a map of the route.
  6. Select Go when you are ready to navigate.
