What is Automatic Interval Categorization?
When going for a run, select watches can generate intervals by utilizing the lap button. This can be helpful for instances when you did not create a custom interval workout.
Watches compatible with the Automatic Interval Categorization feature will categorize your laps as warm-up, run, or rest periods once the activity is uploaded to Garmin Connect™. Pace will become a factor to determine your intervals.
Screenshot of Garmin Connect Automatica Interval Detection
How Do I Start an Interval Workout on My Watch?
The following steps should work for most watches. For specific instructions for your watch, see “Starting an Interval Workout” in your owner's manual.
For select models, you can enable Open Repeats under the Run activity profile to track intervals on your watch.
  1. Select the Run profile on your Watch.
  2. Select Training or press Watch with circle on middle left side MENU then select Training
  3. Select Quick Workout.
  4. Select Intervals
  5. Select Open Repeats.
  6. Confirm if you want to start with a warm-up or not.
From here, use the Watch with circle on bottom right corner BACK/LAP button to transition between interval and rest periods.
Compatible Watches:
  • D2™ Mach 1 | D2™ Mach 1 Pro
  • Descent™ Mk3 | Descent™ Mk3i
  • Enduro™ 2
  • Enduro™ 3
  • epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition
  • epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
  • Forerunner® 265 | Forerunner® 265S
  • Forerunner® 570
  • Forerunner® 945 | Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Forerunner® 970
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition | quatix® 7 Pro
  • tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Ballistics Edition | tactix® 7 - Pro Edition
  • tactix® 8 - AMOLED | tactix® 8 - Solar
  • Venu® X1
Related
