Pairing the Montana 710i/760i for the inReach Remote Widget
Some non-inReach Garmin products have the ability to pair with the Montana® 710i and Montana® 760i outdoor handhelds to use some of the inReach® satellite communication features they offer.
Even though both devices need to be in close proximity (10ft) to each other, it can be helpful to strap your inReach device on your pack or person, and then use your smaller non-inReach device for messaging, SOS, etc.
This article walks you through the process of getting these devices paired together.
Enabling inReach Remote Mode on the Montana 710i/760i Handhelds
Select to access the main menu.
Select Setup.
Select Sensors.
Select inReach Remote.
Enabled should be On.
Verification should be Off.
Enabling and Connecting the inReach Remote Widget
Last, you need to pair your compatible non-inReach device. Steps will vary by the type of device you are using.
Garmin Watches
Hold UP/MENU (middle left button).
Select or scroll to Settings.
Select Sensors & Accessories or Connectivity > Sensors & Accessories.
Select Add New.
Select inReach.
The watch will begin searching for and connecting to the inReach device. This can take up to 60 seconds.
Select inReach - (device number) once it appears on the watch.
Once connected, the inReach Remote widget should be enabled automatically. If it is not, refer to "Customizing the Widget/Glance Loop" in your watch's owner's manual for instructions to add it.
From the watch face, scroll to the inReach Remote widget to see your messages. While viewing the inReach Remote widget, select START/STOP to access the menu for SOS, Messages, or Tracking.
Edge Cycling Computers
For steps to enable the inReach Remote widget on a compatible handheld, refer to the device owner's manual below.
These are general instructions that should work with most compatible chartplotters. For more detailed instructions, refer to your chartplotter's owner's manual.
On the chartplotter, select A/V.
NOTE: If you do not see A/V, select OneHelm™ first.
Select Gauges.
Select inReach.
Select Start Pairing.
The chartplotter will begin searching for and connecting to the inReach device. This can take up to 60 seconds.
If necessary, compare the code on the inReach device to the chartplotter, and select OK if they match.
Automotive Devices
For steps to enable the inReach Remote widget on a compatible automotive device, refer to the articles below:
