Languages Found on Outdoor Handhelds
Garmin outdoor handhelds are preloaded with several different languages, and can install others by using Garmin Express™ software. Languages preinstalled to, and compatible with, outdoor handhelds vary by the region the handheld was designed for. For instance, devices designed for Asian countries will typically support several Asian languages, where devices designed for the North American market may not support any Asian languages.
To determine what languages are already installed on your outdoor handheld, refer to the Language setting in your System settings. Searching your Owner's Manual for "language" will provide you steps for finding these settings on your handheld.
Adding Languages with Garmin Express
Use these steps to add compatible languages to your handheld.
  1. Plug your handheld into a computer.
  2. Open Garmin Express.
    NOTE: If needed, install the Garmin Express program.
  3. Select or add your handheld to Garmin Express.
  4. Select Tools & Content.
  5. Select Utilities.
  6. Select Language Files under Optional Updates.
  7. Check the languages you would like to add.
  8. Click Install Now.
  9. Wait for the sync to complete.
The selected languages are now available on your handheld.
