Best Practices When Connecting A Sensor to a Garmin Device
Garmin® devices that can be used with wireless sensors will connect via ANT+‍® technology or BLE (Bluetooth® Low Energy). ANT+ is more mature connection type that often has more features, The information on this page will apply to compatible third party sensors that can broadcast via ANT+ or BLE and the following Garmin sensors:
  • Cadence Sensor 2
  • HRM 200
  • HRM 600
  • HRM-Dual™ monitor
  • HRM-Fit™ monitor
  • HRM-Pro™ monitor
  • HRM-Pro™ Plus monitor
  • Rally™ pedals
  • Speed Sensor 2
  • Vector™ 3 pedals
NOTE: If using an HRM 200 or 600, see: What Are Open and Secure Connection Types in Garmin Accessories?
I Have a Dual-Protocol (ANT+/BLE) Sensor, Which Protocol Should I Use?
When deciding on which protocol to use, consider the following:
ANT+ Data Advantage
The ANT+ protocol allows more data to be sent than the BLE version. For instance, the ANT+ power meter protocol supports Cycling Dynamics, Pedal Smoothness, and Torque Effectiveness. None of this data is currently supported over BLE.
NOTE: Not all Garmin devices can connect to all sensor types. Check your owner's manual to determine if your device is compatible with power meters.
ANT+ Concurrent Connectivity
If you want to pair the sensor to more than one device/app, then pair using ANT+ on the fitness device to leave the BLE channel open for use.
  • The ANT+ protocol allows a single sensor to be connected to multiple devices at the same time (E.g. an Edge® cycling computer, a Forerunner® watch, and Zwift with an ANT+ dongle).
  • If you have several concurrent sensors, use ANT+ as you have support for a greater number of concurrent connections.
  • Devices that support  a sensor pool of 30 Sensors, with 12 concurrently connected sensors (9 ANT+ and 3 BLE)
    • Edge® 530
    • Edge® 540 | Edge® 540 Solar
    • Edge® 830
    • Edge® 840 | Edge® 840 Solar
    • Edge® 1030 | Edge® 1030 Plus
    • Edge® 1040 | Edge® 1040 Solar
    • Edge® 1050
    • Edge® Explore 2
    • Edge® MTB
  • The Edge® 130 supports a sensor pool of 20 sensors, from that pool it can support up to 8 concurrently connect sensors. This is made up of 6 ANT+ and 2 BLE sensors.
  • Some sensor types can only have a single sensor connected at a time (e.g. power meters) and connecting one will disconnect all other sensors of the same type.
BLE Concurrent Connectivity
Many BLE sensors are limited to a single connection which would not allow the sensor to be connected to your device and software platform at the same time. The exception being the following Garmin sensors:
  • Garmin sensors that support 2 concurrent BLE connections:
    • Cadence Sensor 2
    • HRM-Dual™ monitor
    • Speed Sensor 2
    • Rally™ pedals
    • Vector™ 3 pedals
  • Garmin sensors that support 3 concurrent BLE connections:
    • HRM 200
    • HRM 600
    • HRM-Fit™ monitor
    • HRM-Pro™  monitor
Related
