Pairing the GRID™ (Garmin Remote Input Device) with a Compatible Garmin® Chartplotter
Before you can use a GRID™ remote input device with a chartplotter, you must pair the devices. You can initiate the pairing of the devices from the chartplotter or from the GRID remote input device.
Pairing the GRID Device with the Chartplotter from the GRID device
  1. On the GRID remote input device, Press + and HOME at the same time. A selection appears on all of the chartplotters on the Garmin® Marine Network.
  2. Rotate the wheel on the GRID remote input device to highlight Select on the chartplotter you want to control with the GRID remote input device.
  3. Press SELECT.
Pairing the GRID Device with the Chartplotter from the Chartplotter
  1. Select Settings > System > Station Information > GRID Pairing > Add.
  2. On the GRID remote input device, press SELECT.
If you experience trouble when attempting to pair, please try the following:
  1. Ensure the GRID remote input device is receiving power.
  2. Check Garmin Marine Network connections.
  3. Update the software on the chartplotter.
