Using the Surfline Widget With a Compatible Garmin Watch
This article will provide instructions to use the Surfline Widget on your compatible watch, listed below. With the Surfline Widget, you will have quick access to the five nearest beaches and their surf conditions. These conditions include surf rating, tide, wave height, and wind.
Compatible Watches
  • Approach® S50
  • Approach® S70 - 42mm | Approach® S70 - 47mm | Approach® S70 - TaylorMade® Edition - 47 mm
  • D2™ Air | D2™ Air X10
  • D2™ Mach 1 | D2™ Mach 1 Pro
  • Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
  • Descent™ G2
  • Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
  • Descent™ Mk3 - 43 mm | Descent™ Mk3i - 43 mm | Descent™ Mk3i - 51 mm
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • epix™ (Gen 2) - Standard Edition 47 mm| epix™ (Gen 2) - Sapphire Edition 47 mm | epix™ (Gen 2) - Porsche Edition
  • epix™ Pro (Gen 2) - Standard Edition 42 mm| epix™ Pro (Gen 2) - Sapphire Edition 42 mm
  • epix™ Pro (Gen 2) - Standard Edition 47 mm| epix™ Pro (Gen 2) - Sapphire Edition 47 mm
  • epix™ Pro (Gen 2) - Standard Edition 51 mm| epix™ Pro (Gen 2) - Sapphire Edition 51 mm
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
  • fēnix® 7 - Standard Edition | fēnix®7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner® 55
  • Forerunner® 245 | Forerunner® 245 Music
  • Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
  • Forerunner® 265 | Forerunner® 265S
  • Forerunner® 570
  • Forerunner® 745
  • Forerunner® 945 |Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Forerunner® 970
  • Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
  • Instinct® 3 - AMOLED | Instinct® 3 - Solar
  • Instinct® 3 Tactical Edition - AMOLED | Instinct® 3 Tactical Edition - Solar
  • Legacy Hero Series: Captain Marvel |First Avenger
  • Legacy Saga Series: Darth Vader™ | Rey™
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
  • quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
  • quatix® 7 Pro
  • tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
  • tactix® 8 - AMOLED | tactix® 8 - Solar
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
  • Venu®
  • Venu® 2 | Venu® 2 Plus
  • Venu® Sq | Venu® Sq - Music Edition
  • Venu® X1
  • vívoactive® 4 | vívoactive® 4S
How Do I Install the Surfline Widget?
  1. Open the Garmin Connect IQ™ app.
  2. Select the Search tab.
  3. Select the Search All bar.
  4. Look up Surfline by Garmin.
  5. Select Install.
  6. Select Allow, if a permissions window populates.
The Surfline Widget will now sync content over to your Garmin watch.
How Do I Open the Surfline Widget?
To access the widget do the following:
  1. Navigate through the widget or glances loop on your Garmin watch.
  2. If the Surfline widget did not automatically show up in the loop you will need to enable it.
    • Access the menu on your Garmin watch.
    • Select Settings.
    • Select Widgets or Glances.
    • Select Add.
    • Locate and select Surfline.
    • Return to the watch face and navigate through your widget or glance loop again.
  3. Locate the new widget and select it to view details.
To remove or add a widget see your owner's manual.
How Do I Update the Location?
If the Surfline Widget does not provide the nearest beach from your location, try the following:
  1. Confirm you are paired and connected with the Garmin Connect app.
  2. Navigate to the Surfline widget / glance on your Garmin watch.
  3. Select the Surfline widget / glance.
  4. Select Update Beaches.
Surfline updates information twice a day once before sunrise and again in the afternoon.
Related
