Service History App
The Service History app on these devices allows you to keep track of the services you've had done to your bike or other vehicles. Service History even allows you to create your own categories so you're not boxed into a pre-set list. This allows you to track the service history for as many bikes and/or vehicles as you wish.
Your device will allow you to keep up to 30 Service History categories. Each category will hold up to 50 service records.
To Add a New Service History Category
  1. Touch Apps
  2. Touch Service History
  3. Touch the menu button (three horizontal lines)
  4. Touch Add Category
  5. Enter the desired name for the new category
    • There is no character limit for category names, although very long category names may not display in their entirety on the Service History page.
  6. Touch Done
Categories may have duplicate names, so if you are tracking the same service (e.g., Air Filter Change) for multiple vehicles (e.g., Harley, BMW, etc..), you may want to designate this in the category name to avoid confusion (e.g., "Harley Air Filter Change," "BMW Air Filter Change," etc.
To Change the Name of a Service History Category
  1. Touch Apps
  3. Touch the category you'd like to rename
  4. Touch the menu button (three horizontal lines)
  5. Touch Rename Category
  6. Enter the desired name for the category
  7. Touch Done
The new name will appear at the top of the screen and on the Service History page.
To Delete a Service History Category
  1. Touch Apps
  4. Touch Delete Categories
  5. Touch each category you'd like to delete or touch Select All if you would like to delete all categories
  6. Touch Delete
All selected categories will now be deleted.
To Add a Service Record
  1. Touch Apps
  3. Touch the desired category
  4. Touch Add Record
  5. Enter the current mileage for the bike or vehicle that the service record applies to
    • Current mileage may only be entered in whole numbers up to six digits long.
  6. Touch Next
  7. Enter a comment, if desired
  8. Touch Done
The service record will display at the top of the list.
To Edit a Service Record
  1. Touch Apps
  4. Touch the desired service record
  5. Touch the item(s) you'd like to edit
    • "Comment" allows you to edit, clear, or type a new comment for the record.
    • "Odometer" allows you to change the mileage for the selected service record.
    • "Date" allows you to change the date that the service record took place on.
The service record's details will now be changed.
To Delete a Service Record
  1. Touch Apps
  5. Touch Delete Records
  6. Touch the service records you would like to delete or touch Select All to delete all records
  7. Touch Delete
All selected service records for the selected Service History category will now be deleted.
