Xero X1i Crossbow Scope Display Settings
There are many different options for the display on the Xero® X1i crossbow scope. The display setup will look different for each user based on how their eye perceives light. Different brightness and color settings can help improve your sight picture.
How to Adjust the Brightness on the Xero X1i Scope
The Xero X1i scope has an ambient light sensor that automatically adjusts display brightness as conditions change. If at any time you want to change the brightness level, simply tap the Up or Down buttons while on the hunt screen.
If you want to turn off auto brightness from the hunt screen.
  1. Press the OK button to open the main menu.
  2. Highlight the gear icon X1i Gear Icon and press OK.
  3. Highlight Pro Settings and press OK.
  4. Highlight Auto Brightness and press OK to toggle off.
How to Adjust the Display Color on the Xero X1i Scope
You can choose between 7 different colors for display options on your X1i scope.
To change the color of your display or aim point.
  1. Press OK to open the main menu.
  3. Highlight Display and press OK.
  4. Highlight Color and press OK.
  5. Highlight Display Color and press OK to cycle through the colors.
  6. You can also highlight Aim Point Color and press OK to cycle through an alternate aim point color.
Automatic Display Color
Automatic display color will allow you to choose a display color option for dark conditions and bright conditions.
From the hunt screen.
  5. Highlight Automatic Display Color and press OK to toggle on.
  6. Highlight Bright Conditions and press OK to select a color option.
  7. Highlight Dim Conditions and press OK to select a color option.
  8. Highlight Back and press OK.
Your display will now automatically alternate between the two colors selected using the ambient light sensor.
How Does the Display Time Out Work
To save battery power the default display is set to time out after 20 seconds. When the screen is close to the time out while in Hunt Mode, a "!" with a countdown timer will appear next to the aim point. Tap any button to reset the timer. If the device times out, tapping any button will wake the scope to where it was when the timeout occurred. To adjust this setting.
  4. Highlight TimeOut.
  5. Press OK to cycle through the timeout options.
Available timeout options are:
  • 20 seconds
  • 40 seconds
  • 1 minute
  • 2 minutes
  • 5 minutes
Simplified Display on the X1i
There is a simplified display on the X1i that will display the range and aimpoint only.
  4. Highlight Range and Aimpoint Only and press OK.
This will simplify the screen displaying only the battery indicator, the range point and then the aim point once ranged.
The Display Appears Blurry
To focus to your exact eyesight, you need to adjust the focus using the adjustable eyepiece. The scope features +/- 2 diopters of adjustment. Start by rotating the eye piece ring all the way in, then back it out one complete revolution. From there, experiment with rotating in or out until you reach focus of the display and the visual scene.
You can also make adjustments to the brightness levels. In dim light if the display is set to a high brightness this can cause the display to appear blurry.
Related
