Rally Series and Vector 3 Series Status LED Lights
The Rally series and Vector 3 series  power meters feature status LEDs on the end of the spindle located on the inside of each crank arm. Single sided power meters will only have a status LED on the left pedal. The pedals do not flash an LED when the batteries are low in order to conserve the remainder of their life.
Vector pedal LED location
Error Codes
LED Light StatusPedal StatusTroubleshooting Tips
1 red flashThe Vector or Rally system is active and working properly.None
3 green flashes every 10 seconds (Vector 3) / every 5 seconds (Rally)The pedal is searching for the other pedal.Confirm opposite pedal has good batteries and pedal is in working condition.
Alternating red and green flashesA software update is in progress.Wait for software update to finish installing
20 green flashes
The software update was successful.
The pedals found each other successfully and are up to date.
None
20 red flashes
The software update failed.
The left pedal could not find the right pedal or failed to update the right pedal.
Reapply software update
Related
