Navionics Boating: Editing a Route
Editing a Route During an Active Subscription
To edit a route:
  1. Select Route > My Routes Archive or Menu > Routes to select an item
  2. Tap Route > Edit to edit the current route displayed
  3. Select Automatic1 or Manual
Press on the route line to add an additional point and drag it to your desired location or drag an existing point to a new location.
For automatic edits, the route will automatically be adjusted to take in this change. For manual edits, only the one point will be adjusted.
To save your changes tap GO to start navigation or SAVE to your archive without starting navigation.
Editing a Route Without an Active Subscription
  2. Press on the route line to add an additional point and drag it to your desired location or drag an existing point to a new location
  3. To save your changes tap SAVE
NOTE: Active navigation of a route is not available with an expired subscription.
Reversing Your Current Route
To reverse your current Route, click Route > Reverse. This will swap your starting point and destination.
1 Auto Guidance+ is for planning purposes only and does not replace safe navigation operations.
