Using the inReach Remote With a Garmin Handheld
Pairing an inReach® satellite communicator with the inReach Remote widget allows the following actions from a compatible Garmin handheld:
  • Send custom messages
  • Send check-in/preset messages1
  • View message replies
  • Start/stop tracking
  • Trigger an SOS
Important Notes Before Using the inReach Remote
  • The latest software versions should be installed on the inReach Satellite Communicator and compatible Garmin handheld. For detailed instructions, see - Help with Product Updates.
  • An active inReach subscription is required to use the features of the inReach Remote on a compatible device.
  • Both devices need to remain within close proximity (10 feet) to use the inReach Remote.
  • The inReach Remote widget can be used while the inReach device is simultaneously paired with a smartphone.
inReach Remote Device Compatibility
NOTE: Only devices compatible with the inReach Remote and equipped with ANT+ can be paired (inReach SE®+, inReach Explorer®+, and older DeLorme® satellite communicators are not compatible).
Before attempting to pair, ensure both the inReach device and Garmin handheld are compatible with inReach Remote. To check compatibility, see - Garmin Products That Support the inReach Remote Feature.
Enabling inReach Remote on Active inReach Device
The inReach Remote sensor can be turned on or off in the Sensor settings of the Setup menu on the inReach device.
Alpha® 200i Dog Tracking Handheld
  1. Select Setup.
  2. Select Sensors.
  3. Select inReach Remote.
  4. Select Enabled to turn On.
  5. Choose a Verification option:
    • On: Allows pairing only to approved inReach Remote devices.
    • Off: Allows pairing to any nearby inReach Remote devices without approval.
With the inReach Remote sensor enabled, the Alpha 200i is ready to pair with compatible devices.
Alpha® 300i Dog Tracking Handheld
  1. Select alpha 300 setup from the main menu.
  2. Select Sensors.
With the inReach Remote sensor enabled, the Alpha 300i is ready to pair with a compatible device.
GPSMAP® 66i, 67i, 86i, and 86sci Outdoor Handhelds
  1. Press MENU twice to access the main menu.
  2. Select Setup.
  3. Select Sensors.
  4. Select inReach Remote.
  5. Select Enabled to turn On.
  6. Choose a Verification option:
With the inReach Remote sensor enabled, the GPSMAP 66i/67i/86i/86sci is ready to pair compatible devices.
inReach Messenger Satellite Communicator
  1. From the home page, press Left Arrow Button or Right Arrow Button to scroll through the main menu options.
  2. Select SETTINGS Wrench.
  3. Select inReach Remote Remote icon.
  4. Select Status to set the inReach Remote function to On.
With the inReach Remote sensor enabled, the inReach Messenger is ready to pair to a compatible device.
inReach Messenger Plus Satellite Communicator
  1. From the home page, press Left Arrow or Right Arrow to scroll through the main menu options.
  2. elect SETTINGS Gear Wheel.
  3. Select inReach Remote Remote Icon.
With the inReach Remote sensor enabled, the inReach Messenger Plus is ready to pair with a compatible device.
inReach Mini Satellite Communicator
  1. From the home page, press OK to open the main menu.
  2. Select Setup.
  3. Select ANT+.
  4. Select Status.
  5. Select On.
With ANT+ enabled, the inReach Mini is ready to pair to a compatible device.
inReach Mini 2 Satellite Communicator
  2. Select Settings.
  4. Select Status to enable inReach Remote.
    • The status will change to On with the toggle up when inReach Remote is enabled.
      inReach Mini 2 inReach Remote Status On
  5. Select Verification to enable or disable verification:
With the inReach Remote sensor enabled, the inReach Mini 2 is ready to pair to a compatible device.
Montana® 700i, Montana® 710i, Montana® 750i, and Montana® 760i Outdoor Handhelds
  1. Touch Home .
  2. Touch Setup.
  3. Touch Sensors.
  4. Touch inReach Remote.
  5. Touch Enabled to turn On.
With the inReach Remote sensor enabled, the Montana 700i/750i is ready to pair to a compatible device.
Enabling inReach Remote on a Handheld
For steps to enable the inReach Remote widget on a compatible handheld, refer to the device owner's manual below.
1 Check-in messages have replaced preset messages as of September 27th, 2022. inReach® accounts set up prior to this date will still have preset messages available, but any new accounts created after this date will use check-in messages.
Related
