Tread Device Showing a Computer Icon in the Vehicle
Your device may show an icon of a GPS device connected to a computer when plugged into the vehicle. This icon means the device is in file transfer mode. This is used specifically for connecting to a computer. The device may also display the message "The device is not charging. Use a different power source."
This May be Due to the Following Reasons:
- A USB cable is plugged into the device instead of the Garmin-provided vehicle power cable.
The device enters file transfer mode when connected to a USB port or USB cable since they provide less power to the device.
The amount of power it receives from the connected cable determines which mode it uses.
The USB cable is used for plugging the device into a computer for data transfer.
- The provided vehicle power cable must be used. For compatible vehicle power cables see Automotive Accessories.
- A third-party cable is being used to plug the device into the vehicle (Examples below).
A mobile phone charger or adapter.
A 12V USB adapter manufactured by a different company.
See Using Third-Party AC Chargers, Cables, and Other Accessories with Garmin Automotive Devices.
- In more rare cases, the power cable may be damaged.
A replacement cable can be purchased from a Garmin dealer or the Garmin Online Store.
Contact Product Support if a replacement cable does not resolve the issue.
